Winton
JimmyB
23 Feb 2018
6,947
921
69
Weston-super-Mare
www.tumble-down-falls.co.uk
But how is it for pulling power ? If I were to buy one and use it to pull trains, instead of cleaning track, would it serve me well ?
I think the LGB wagon attachment works in a similar way, and pulled by a Playmobile battery loco just as good.
3,521
Well I only have the 'clean machine' version..
This uses 6 x 'AAA' batteries, so is a little slow, and I guess would have a limited run-time if you put much behind it?
IF it stays dry.. AND IF I cut the grass (can't see the track at the moment) I will see what it will pull..
NOTE: My track is (literally) thrown-down on the grass.. Gradients are severe in places, and the track is far from level!
kim
retired at last
27 Apr 2015
792
563
72
Cleveleys
This ran for 2 hours and fifteen minutes this afters, fully charged 1100mAh batteries and metal wheels on box car and caboose and level track.
3,521
I took the abrasive pads off, and it will run round my dodgy oval.
251843
It did better with the load than the D10, but to be fair, I have taken the weight out of the D10.
Both slip, but the little Piko does better, as it has more weight. - And traction tyres.
251852
The block weighs-in at over 2.3Kg - As high as the kitchen scales will go
251853
As you can see, this is a pretty vicious gradient, the track is filthy, and cross-levels are silly as well!
600mm level, so 1:24, worse in places, but I tend to run with the worse gradient running downhill.
kim
retired at last
27 Apr 2015
792
563
72
Cleveleys
A lazy railway day, 2-8-2 Mikado out with a nice rake of coaches.
kim
retired at last
27 Apr 2015
792
563
72
Cleveleys
A short train today. Word of caution to anyone on american outline thinking of buying the road crossing from Piko be aware that the oversize tail marker lamps on the drovers caboose don't fit between the crossing signs.
kim
retired at last
27 Apr 2015
792
563
72
Cleveleys
The sun is shining in sunny Blackpool so new spur installed into Universal Plant, sales and hire, with a back hoe unloading the flat via the load/unload ramp with bucket being used for bracing.
kim
retired at last
27 Apr 2015
792
563
72
Cleveleys
Santa Fe F7A makes an appearance with two streamliners on the main and Rio Grande 2-4-0 oil burner with hoppers on the local both posing outside Universal Plant admiring the stock on sale.
kim
retired at last
27 Apr 2015
792
563
72
Cleveleys
Mallet 250 running double tender on a log train. The second tender is from mallet 251 which is in the shops having been remotored and then the chip went bang, currently awaiting new xls from Mark. My other problem is that I do like 250 with two tenders so I am now on the lookout for two tenders, mission impossible methinks!
kim
retired at last
27 Apr 2015
792
563
72
Cleveleys
Had a pottering day today, wife's out so time for beer and a train. Great idea except it has started raining!! Still got me beer though. Had a problem with lgb drovers caboose catching the buckeyes ona Piko crossing so that has been remedied with a hacksaw, brass wire pins and a blob, or two, of glue. Post sawn off near the post base and the post reattached to the base one post width further away from the track.
kim
retired at last
27 Apr 2015
792
563
72
Cleveleys
Mallet 251 is now on roster again with a new xls chip freshly fitted. A strange thing is that the sound is different to the older chip in mallet 250, mmmmmm. The wires in the connectors are track feed and motor wires, having been tested on dc, the other loose wires are speaker and volume control.
kim
retired at last
27 Apr 2015
792
563
72
Cleveleys
A train of gons on the never ending inner loop drawn by mogul 491. Bought this years ago from Bill of Carnforth Models after he had put a Phoenix sound system into it, he sadly passed away about?? 7 years ago. He would always do a deal but you would never come out on top, at the time you would think you had!P_20190617_155902_1_p.jpgP_20190617_155930_1_p.jpgP_20190617_160029_1_p.jpg
kim
retired at last
27 Apr 2015
792
563
72
Cleveleys
Found this old Aristo tender whilst having a clean up, I think 251 suits it very well indeed.
Also received via e-bay a prospector and his donkey.
P_20190630_163849_1_p.jpgP_20190630_163907_1_p.jpgP_20190630_164041_1_p.jpgP_20190630_164050_1_p.jpg
kim
retired at last
27 Apr 2015
792
563
72
Cleveleys
The Aristo tender has now had the Great Northern decals and running number removed, metal wheels and weight added and topped off with a dog house. Just need to buy a rattle can to spray over the blemishes.
Whilst this is pictured with mallet 251 it is going to be partnered with mallet 250 (currently stripped down awaiting chip) and 251 will be pulling 2 tenders in operation.
I use Never Dull to remove decals with a bit of elbow grease.
P_20190701_133645_p.jpgP_20190701_133702_1_p.jpgP_20190701_133717_1_p.jpgP_20190701_134049_1_p.jpgP_20190701_133807_1_p.jpgP_20190701_133817_1_p.jpg
3,521
Why have you put a Sedan-Chair on top of that tender?
:giggle::giggle::giggle:
kim
retired at last
27 Apr 2015
792
563
72
Cleveleys
For the fat controler of course. Apparently he's always in the doghouse!!!
