playmofire
I wonder if they would be less prone to uncoupling than some of the LBG Toy Train are?I think they may be early Newray?
ECR are doing these on EvilBay, and they appear to have a downward hook?
they are just as reliable, as LBG/Playmo.I wonder if they would be less prone to uncoupling than some of the LBG Toy Train are?
Was it a glued job or a moulding that has been trashed due to a nose dive from a height?Just caught this in time, I think?
A liberal bath in IPA, and the other side is coming away as well. - Suggests the glue is coming to the end of its life?
You start one job..........
Jon, it has been 'hacked' and glued..Was it a glued job or a moulding that has been trashed due to a nose dive from a height?
Scary conversion, I can see the desire but a scratch chassis would have been a more robust and expensive job. I expect in the day they would have had a lot of punters looking for a 32mm gauge version.Jon, it has been 'hacked' and glued..
These were a very limited number, converted to 32mm gauge by GRS. The blocks cut-down so everything could be moved inwards.
There are gaps where the cuts have not been very accurate.
I have bonded where it touches with Tamiya thin cement. I will now use something thicker, to fill the gaps and add strength.
These are not the most robust units to start with, and the modifications don't help.
Cat-in-a-boxJust before we left for Wales...
This arrived:
I recently flogged an RCS control system to a guy in the 16mm society that was desparate to get a replacement for a failed one. The one I had likely been sitting around for a decade and a half never having been used.Something of a blast from the past:
Brandbright installed (I believe) RCS-RC radio control installation,with Dallee sound.
There is a battery pack buried under that lot, which needs replacing.
I just need to get all back together now..
If it was Brandbright, the on/off switch is likely to be on the front buffer beam - a practice that I dislikeSomething of a blast from the past:
I would guess at least 2009/10 possibly earlierThe RCS-RC Tx24, would appear to be well before 2012..
27mHz technology.
Yes, charging socket and switch on front buffer beam..
