I envision using the most effective smoke unit (whichever that might be) and stringing wires from the smoke unit through the loco and the tender to a plug that can connect to a plug in the current trailing main battery car that would now house an additional battery (Lithium) with charger receptacle and switch and would be switched on when train power was switched on. I would like it to provide battery juice with off and on cycles so the smoke unit could virtually smoke for the entire run yet not overheat or run dry. I'm not sure how to do this electronically and would appreciate any assistance. Thanks, Jim
