Hi,
I just wondered if anyone had any ideas or suggestions concerning the Massoth Train Detection module?
We recently installed a US style grade crossing (level crossing) flasher unit and sound module from Shiloh Signals on our line. The system runs off small push-to-make sensors which are triggered by the flanges of a passing wheel. It works well at the moment but it does have some big drawbacks. Here are a couple of photos showing it installed:
One of the biggest problems is that the unit is switched on by one sensor as it enters the town, and then switched off by a sensor on the other side of the town as it exits. A train therefore must pass through the town if it is to successfully switch the system on and off. This would be fine under normal circumstances but as it is a destination point for switching and shunting, trains often enter and leave in the same direction and thus cannot trigger the unit to switch off after they pass.
I would like to instead trigger it via DCC using a detection module so that as long as anything is in the town area then the flasher system will be on. I thought to hopefully dispense with the sensors and control the flasher system with a small decoder (function only or maybe a single channel accessory decoder?) and with my Massoth system this could in turn be triggered by the presence of a train? My question is this, would this potentially work as I already have a feedback module in a drawer collecting dust, it just needs the RC upgrade? Is it easy to do with the 1200Z?
Secondly, how sensitive is the Massoth detection unit? I know a loco would trigger it off but would the lights in say a caboose? The reason I ask is that I don't want it to stop until everything has cleared the crossing. The third problem is that there is a 4 channel point decoder fed from the in the area controlling the two points (underneath the petrol station in the photo!), would that also cause false triggerings of the module?
Many thanks in advance for your thoughts and ideas!
