chris m01
I often have difficulty remembering which way points are set and following recent changes I now have the ability to isolate the tracks in each passing loop/station. It was clear that I needed some sort of indication system.
My Aristo Train Engineer is used to control track power voltage, eight points and two section switches. The section switches use the normal switch (point motor) accessory unit. One is coupled to an old point motor with switch mechanism and the other to a latching relay set up. My points have LGB motors with the (power) switch accessory added.
The track layout is roughly as shown here
