D
Deleted member 1986
Guest
Thinking outside the Box!
B & Q Loft Stilts 12 for £15.00, less the Wednesday Discount!
Looking for a Portable, Semi- Permanent or even Permanent, easy on the pocket and the Back!!!!!!!
Plastic is easily drilled, drill holes in bases, Metal Tent Pegs, to affix on a lawn, bases can be stood on Patio Area, or for a more permanent fixing, bases could be concreted in, as ever imagination and ingenuity will provide the answers!
http://www.diy.com/rooms/diall-loft...src=aw.ds.ds&dclid=CJDxt-PxwdMCFYkTGwodNBgJsA
Also available singly at £1.78 each.
http://www.diy.com/rooms/diall-loft-storage-stilt/252222_BQ.prd?icamp=recs&rrec=true
No B & Q local to you, they are available at Screwfix, though they will cost £19.99.........
http://www.screwfix.com/p/ybs-loft-storage-stilts-0-15-x-0-21mm-12-pack/65421
Wickes
Decking Boards 3 for the price of 2! Works out at £2.33 a length............
http://www.wickes.co.uk/Wickes-Value-Deck-Board-25-x-120mm-x-1-8m/p/145255
Timber to form circle of R1 curves, template required, as each piece of track turns 30 degrees, requires cut of 15 degrees from perpendicular at each end, decking boards are not quite wide enough, the following are of sufficient width to form the sections for the curved track.
http://www.wickes.co.uk/Wickes-Treated-Sawn-22-x-150-x-3000mm/p/166438
Or
Gravel boards....
http://www.wickes.co.uk/search?q=gravel boards
Due to differences in thickness of the timber, again depending on whether all Decking Boards, Sawn or Gravel Boards are used, packing pieces may be required.
Screwfix have a selection of Glazing Packers of varying thickness, or wedge strips that are used for levelling kitchen furniture.
The plastic composition of the Loft Stilts is better suited to Pan Head Screws or Bolts, again Screwfix have a selection to suit, plus Cabinet Makers products that can be utilised to join the various sections and boards together.
