GAP
G Scale Model Trains, 1:1 Sugar Cane Trains
Sound advice from Greg there.While I love your aspirations.
Before making an 80 passenger car, and a complex locomotive, why not make a box car or something more simple.
Then you can learn about trucks, equalization, bolsters, track and wheel gauge, etc.
All fundamentals you will need for more complex things. Say you wanted to be a Formula 1 driver, your first race would not be at Monza or Monaco, but in a go cart on a local track.
Similarly, trying to handle complex things without even the fundamentals seems pretty hard to do, very few people, even mechanical engineers have started at 1,000 miles an hour!
Make something. Learn the basics of 3d printing. Make a simple box car, you will have enough challenges with that. Setting your sights too high initially will probably end in frustration.
To help you on your way have a look at these downloads, I have printed the the bogies and they work well.
Bogies
Bogies for LGB cars by jockelill
Bogies for LGB-cars. Will fit for instance the heavy load car I've created but also other cars. I've added one version with hook holder (standard LGB hook will fit) and one version without holder. I've also added complete files for reference or so you can download and use in your own projects...
Bogies for LGB cars
Couplers
Loop and hook
LGB Kupplungshaken
LGB Kupplungshaken für den Sb Tragwagen und andere Modelle es ist ein Remix aus thingiverse thing:4718704 thingiverse thing:4343616 sie wurde so angepasst das sie für meine Bedürfnisse passend waren. Vor allem das abkippen nach unten wurde verbessert LGB coupling hook for the Sb flat car and...
knuckle
Knuckle Coupler for LGB by dagnall53
Updated Dec 2019:added the "V2" Opening Knuckle versions from the Motorised coupler..Updated Oct 2017: I have added the "fixed 7 degree" version of my revised geometry couplings here. These are single piece parts, and need the lock ring to push them down firmly in the housings. It has similar...
Link and pin
LGB kupplung mit puffer by GARTENBAHN_POLDERBAAN
for LGB 45770 and more. no chain included ofcourse. advice: metallpin
Wagon print
Spur G Flachwagen
Flachwagen an Piko G angepasst. Flachkopf 3x10mm für die federn und Senkkopf 3x10 zur haken Befestigung Drehgestell
That should keep you busy for a while
