Steam Sound
zman50
22 Feb 2019
164
4
68
Wisconsin
United-States
I have a P.H. Hobbies steam sound board V2-6 that was added to a tender, not original to tender. It has decent sound like hissing, bell clanging, whistle, and chuff chuff. The problem I have is when it first starts out there is a annoying, lets call it squelching sound. It will go away after the tender gets rolling about 5-10 seconds, and then the sound is ok. It does this every time the tender starts to roll. There is a volume control but turning it down does not get rid of it, only if the volume is turned all the way down. Thanks for any info.
8 Mar 2014
7,806
972
San Diego
Armenia
www.elmassian.com
I gather this is track power?
Sounds like a bad or missing battery, which supplies power to the sound unit until the track voltage gets high enough to power the unit.
So:
track power or not?
model number of the board (It's usually on the board a 1000, 2000, 3,000, etc. number
is there a small 9v battery or connectors for one?
That should get us going...
example: (model number S3005 is in bottom right corner)
8 Mar 2014
7,806
972
San Diego
Armenia
www.elmassian.com
Bottom right on my screen on a pc... right below the square prom, near the speaker... is the speaker on the right on your screen? It's not here, speaker shows on the right.
Notice I specified the model number, to the right of the copywrite symbol, above the work copyright.... there's other writing all over the board, typical of PH Hobbies.
3,521
Greg,
Apologies, my bad! - Excuse, it was BC (before coffee) ;)
I had picked up about the battery, and had gone for the battery connection on the board.. :(
(I will delete the post, a little later)
zman50
22 Feb 2019
164
4
68
Wisconsin
United-States
It is track power, there is no connector for a battery. I will have to take apart again to check model number. It is about 3-4 inches long and 1-1.5 inches wide. Thanks
zman50
22 Feb 2019
164
4
68
Wisconsin
United-States
zman50
22 Feb 2019
164
4
68
Wisconsin
United-States
So:
track power or not?
I finally had a chance to get that number. It says patent pending CB12A2. Hope you can figure something out. Thanks for your knowledge.
zman50
22 Feb 2019
164
4
68
Wisconsin
United-States
Please look for more numbers, a nice high resolution picture would help. the number you gave does not sound right.
No other numbers, but will try to post a picture.
MaidaVale
13 Sep 2023
6
Perth
Zman50
Did you ever get this resolved and do you have any information or manual on the card as I have the same card in a bunch of stuff I have just unpacked. I’d like to test it to see if it works but I am missing some plugs
MaidaVale
13 Sep 2023
6
Perth
Don’t worry folks I’ve got it working and all it plays are Christmas Melodie’s. Nothing else.
