I found a neat little trick on the internet that I though might be useful to someone else.
I am using a phone type plug in charger to power an accessory on a layout I am building and i need to know which is positive. It is usually the 'marked' wire - the one with a stripe or design on it - BUT, I want to be sure.
My meter is 'on site' away from home.
All my LEDs are with the meter (LEDs only work one way round so could be used here).
The trick
Take a glass of water, add a teaspoon of salt. Plug in your charger and put the (LOW VOLTAGE ONLY) wires in the glass. The negative will bubble far more than the positive.
Quick, cheap and easy.
The trick
