gregh said:
I finally twigged to the problem being the fact that the screw underneath was loose and too long, as per many previous posts and this allowed the moving blade to flop around and not seat properly against the fixed rail. So the screw problem is not just an electrical continuity problem.
Now these stupid screws are Torx head, so after buying a small screwdriver I tried to tighten it, but just managed to 'strip' the head.
I suggest that, following Greg's experience, one should
loosen and remove the screw, rather than trying to tighten it. The screw is obviously too long for the blind hole. Also, the TORX screws are probably fitted using a powered driver, hence their use.
Then I would fit a shake proof washer
before re-assembly.
I reckon that a washer should have been fitted at the factory, but for some reason has been omitted and poor QC hasn't picked this up....
