Piko Curved Points
Dtsteam
G Scale, Travel, Steam Boats, Mechanical Music
15
Preston
And does anyone know what the geometry is ? I've had a trawl, including Pikos website, to no avail.
shropshire lad
25 Jan 2010
4,552
12
Sunny Shropshire
The outer curve is Piko R5 and the inner is Piko R3
Girt big things tho!
whatlep
1
Worcestershire
www.facebook.com
Top notch picture Colin. Thanks! :clap:
What are the two mini-curves and how many degrees (of a circle) is the whole shebang?
shropshire lad
25 Jan 2010
4,552
12
Sunny Shropshire
Cheers Peter I'll take some more pics when it's been fitted.
Ah I see Deutsche reichsbahn has answered your question :clap:
gep4
G scale garden railway & indoor layout
South Staffs.
no check rails ? are they such large radius that check rails are deemed not necessary! i am very surprised !
Phil
Trains, Just Trains.
24
28
Oldham, Manchester.
There are check rails, they aren't very clear on the picture.. :clap:
shropshire lad
25 Jan 2010
4,552
12
Sunny Shropshire
Absolutely right :D
Mind you at nearly 3 feet long I wasn't going to do a close up :rofl::rofl:
gep4
South Staffs.
I am very relieved to read that. !! After over 70 years! of railway modelling things have not changed. I have not lost my marbles yet!!
whatlep
1
Worcestershire
www.facebook.com
Deutsche Reichsbahn said:
RADIUS:
Innerer Bogen: G-R3, 52,5° + Gleisstück G-R3, 7,5°
Äußerer Bogen: G-R5, 37,5° + Gleisstück G-R5, 7,5°
http://gscalenews.com/news-piko#10022012
Thanks for that. If I get the message correctly, two of these beasties back-to-back gives a 90 degree curve, inner radius Piko R3 (921.54mm), outer radius Piko R5 (1243.08mm). Crikey!
Colin - does your new point need extensive testing with a wide variety of visiting locos? :D
shropshire lad
25 Jan 2010
4,552
12
Sunny Shropshire
RADIUS:
It certainly does Peter I'll let you know when it's all sorted :clap:
steve parberry
G Scale Trains
2
Just wondering have they changed anything underneath?
Different wires or screws?
KeithT
190
Nr Manchester
In view of the history of the other Piko points I would recommend having a look under the cover plates before installing to check connections AND putting extra insulation between the cross-over wires.
shropshire lad
25 Jan 2010
4,552
12
Sunny Shropshire
If no one has posted any before I make it back home I'll have a look and post some pics if you like?
I bought some R5 points off someone who was nervous about using them and the connections were fine on them. I do however silicone grease the exposed connections on all the points I use outside regardless of their make.
steve parberry
G Scale Trains
2
I dont have a need for any at the moment but, i am sure that a number of members would be intrested following on from Piko's previous issues.
WillemD
35
Belgium
This is the answer I got from my contact at PIKO when the wiring issues were brought up the last time:
It's a problem that's already known by PIKO. We already did some changes there. Seems like the guys with this problem own some of the "older" R5 swichtes.
So, don't expect problems with these curved switches. If you do, immediately contact PIKO, or me. I will then forward it to them.
mike
Master at annoying..
4,467
Rossendale
ah older new switches..all 6 month old.. explains a lot..
KeithT
190
Nr Manchester
deleted
KeithT
190
Nr Manchester
It' s shame they didn't bother to reply to my two emails or the UK importers emails setting out the problems.
As we bought early ones it seems we are 'expendable' as there was no offer to remedy the problem or even acknowledge to us that there were problems..
