Phoenix The Big Sound Diesel 97
AJtheTeacher
2 May 2021
36
5
Magnolia Texas
United-States
Hello Fellow G Scalers!
Thank you everyone that pointed me in the direction of G Scale Graphics Diesel and Light Diesel sound systems. I have been enjoying their sound products and also their graphics.
I have a Phoenix The Big Sound Diesel 97 board and I love it! But I wish to trigger the horn and bells remotely instead of with reed switches. I use track power and at this time do not use DCC. Does anyone have any suggestions? Thanks AJ the Teacher (in Texas)
JimmyB
To trigger remotely you need a remote switch
And track power (without DCC) does not have this facility, which is why reed switches are employed.
The only way forward if you are not going DCC would be a R/C with an on board Rx to trigger the switches, but this seems like a lot of faff and expense.
Greg Elmassian
8 Mar 2014
5,780
754
San Diego
www.elmassian.com
Yes, the 97 was not even DCC capable, pretty early unit.
some reference info on the Phoenix line (scroll down for early stuff)
If you want to remotely trigger sounds on DC, find some old QSI decoders. You can trigger the bell and horn with the reversing switch on an analog supply. There's a small box that was available that would command all 32 sounds on dc layout.
AusrailQLD
10 Jul 2020
46
14
33
Australia
Sounds like you need to find a 2 channel remote relay unit of some sorts.
(I'm guessing you want to trigger both a bell and horn)
FatherMcD
13 Mar 2014
141
15
Idaho
United-States
Any hints on how I should search for this marvelous device on evilbay? Never mind. I searched on Two channel remote relay and got several hits. Duh!
AusrailQLD
10 Jul 2020
46
14
33
Australia
You would need to look up "2 Channel Remote Relay"
The main trouble is, most of these units I've seen require at least 12 volts to operate the 'brains'.
Which means you need to fit quite a few batteries in the loco for it to work.
AJtheTeacher
2 May 2021
36
5
Magnolia Texas
United-States
Thanks for your suggestion . I will be looking into this. AJ the Teacher
AJtheTeacher
2 May 2021
36
5
Magnolia Texas
United-States
They don't draw a lot of current, so the small 12v garage remote battery might be fine.
Thanks Greg. (Sorry for the late replies everyone. My 86 year old Mom is in ICU,) I should have also mentioned that the sound board came with an RCS Remote Cordless Walkaround Controller box that is powered but a 9 volt battery. Unfortunately; I did not receive the receiver that plugs into the Phoenix sound system. There is only the pigtail for it attached to the board. Thanks AJ the Teacher RCS Controller Made In Australia.jpg RCS Controller Receiver Pigtail.jpg .
