I think the Otto block is the same, or at least very similar.
Hi,
The 3 'toy train' locos (Otto / OHO / TT / Atlas / Circus loco etc.) Porter saddle tank and the extremely toy like little red / blue diesel all shared the same chassis / motor block.
However, some of the Porters had their bottom cover screws in a straight line as opposed to the other locos which were in a rectangle pattern.
You can still swap the chassis / motor blocks, but you may need to swap the bottom cover.
Bear in mind that the 'toy train' locos were DC only with no sound, Later porters have had other options added.
Also look out for the country of origin. the far eastern versions were made of a less robust plastic than the original german ones.
I've swapped, chopped and kitbashed several of these loco chassis / motor block without much of an issue.
NB; there were two types of gears used as well. Fine and coarse tooth. Worth checking that if you need to replace cogs or wheelsets.
Hope this helps. (I am informed that the fine toothed gears were mostly used on the locos produced in the far east, as were the porters with the metal hand rails.)
Paul.
