Options to avoid sharp corner, & steep grade ( Hind sight is wonderful)
Granitechops
Granitechops
Narrow Gauge 1/12th scale on 45mm</br>Quarrying &
Sunny Devon Uk
Re: Options for avoiding a sharp corner, Also on a severe gradient ( Hind sight is wonderful)
Had to give the Lobelia a good back & sides so engines could pass!!
Granitechops
Granitechops
Sunny Devon Uk
Even the difficult to grow ( well, for me! )
Lewissia is flowering again after I leant back & broke it off just before Nettys visit
Granitechops
Granitechops
Sunny Devon Uk
That plant in the middle is coming out when it finishes fruiting (tayberry)
so paving will give access to this area
Notice drainage ditch down middle
Granitechops
Granitechops
Sunny Devon Uk
Up around the corner to the right,
just past those tippers,
a pair of points will divide into two tracks to form the start of a long run round loop
One track will run around just above that narrow gap but close to it.
The other one will be this side of it.
Granitechops
Granitechops
Sunny Devon Uk
Looking the other way,
If you compare this with a previous pic,
notice that the drainage ditch is now overhung by the new slabs,
thus maintaining volume of flow,
but leaving a slot for debris clearing.
When track is laid either side, a wood plug with top panel will fit neatly(?) in place to save wheelchair wheels getting locked in
The two tracks will then curve round to the right & into the canal Basin,
being linked by points just under the bridge,
so as run rounds can be made
Between the track visible here & the new tracks,
a quarry track/ road complete with potholes & puddles is envisaged
Granitechops
Granitechops
Sunny Devon Uk
Tayberry gone.
Slabs laid
As there is no immediate likelyhood of track being laid just yet
will use the 'blank canvas' for a photo shoot
Quarry stone heaps what else
Granitechops
Granitechops
Sunny Devon Uk
Different grades of stone
Granitechops
Granitechops
Sunny Devon Uk
I do believe in the digger driver having a days work before him when he starts in a morning
Granitechops
Granitechops
Sunny Devon Uk
Quarries can be dangerous places especially if you dont have 4 wheel drive :D
Granitechops
Granitechops
Sunny Devon Uk
Mustn't leave the trains out of it
Granitechops
Granitechops
Sunny Devon Uk
Drainage ditches have been seriously tested this last few days!!!!
Granitechops
Granitechops
Sunny Devon Uk
Ern on his way from Canal Basin to Longstone Yard
Have forks will eat
Granitechops
Granitechops
Sunny Devon Uk
branch from Longstone Junction to Deep Pit entering Windy Ridge quarry complex
Granitechops
Granitechops
Sunny Devon Uk
Around the curve,
Track side swept clean to keep grit out of tram type tracks
quarry track, other side of drainage ditch, with safety feature.
Larger rocks used to delineate edge of drop off
No fencing for this NG effort
Granitechops
Granitechops
Sunny Devon Uk
Busy scene
4 modes of transport
Granitechops
Granitechops
Sunny Devon Uk
View into Wheal Prosper Mine Adit
The left track curves around behind the tall tree into Deep Pit as far as smaller tree to its left
Granitechops
Granitechops
Sunny Devon Uk
View back towards Longstone Junction
Well out of sight
Granitechops
Granitechops
Sunny Devon Uk
Austin leaving the scene
orange beacon on roof is appropriate I think
Granitechops
Granitechops
Sunny Devon Uk
Drainage ditch this side of the Austin Countryman, has two culverts to take storm water
one just by the barrels ( square)
& the other to left by last wagon partly seen
Granitechops
Granitechops
Sunny Devon Uk
Been playing with some plasticard to make cosmetic bridge sides to add to the deck on the bridge above the entry to the Canal Basin
Drew a curve on piece of plasticard (80thou?)
you can see the alternative shapes that were discarded!!
