I recently was given a rather neglected Fornay. Inspection showed it was basicaly all there but was a 3 pin gearbox. I have done conversions to DCC using the insulate the pin and solder to the motor method, but the last 1 I did was a nightmare.
So this shows what I have done this time. I have only shown the gearbox as the model dismantling is not particularly interesting. Here goes:
First, a gearbox in bits
Next I drilled a hole to math the 1 nearest the motor on the other side
I then made copies (mirror images) of the contact wires from 1.5mm solid copper cable
I cut the top 1 shorter to ensure it could not touch the pick up contact if it turned.
There's more
	There's more
