All,
How do you deal with loco's with more than one decoder fitted?
Programming once a loco is back together, when fitted with more than a single decoder, is problematical.
Either one decoder seems to respond to all the programming requests, or more likely, you get erratic results..
On the larger, more awkward loco's, I tend to fit sub-miniature slide-switches, to allow the decoders to be turned off individually to allow for this.
My thoughts for smaller loco's, where there is probably less room to mount the switches, is to use a 3-pin header arrangement.
Track power to the centre pin, and a feed to each decoder from the outer pin at either end.
The jumper would be wired with all 3 pins connected together, and when normally connected, both decoders would get track-power.
Move the jumper to either pair of centre + outer pins, and a single decoder would get power.
Cheap and simple.
Do any of you have other ways round this problem?
Cheap and simple.
