Hi
I have just activated a Massoth Feedback Module. In the Massoth User Manual for the Feedback Module there is two Automatic Programing Example (1) A Shuttle with an intermediate stop. I followed the instructions and found this worked great after some fine tuning. Programing Example (2) is for a passing siding Two contacts 6 programing functions. I have set this up on a test track with two locos on rollers. I have followed the same programing functions as shown in the User guide on page 9 , the only setting I have changed are the loco address's, I use a magnet to activate the contacts. The scenario loco 2 my loco addressed in Number 1 sequence makes contact with 1a Reed programed for a 15 second delay and then it should Stop. This dose not happen, when I activate the contact, Loco 2 stops no delay waits 15 seconds and starts running again. Loco 7 the other loco when 1a is activated Number 2 programing sequence is suppose to start running this dose not happen. Contact 1a also activates the switch and throws it for number 7 loco to return, this works OK. The contact 1a and 1b are working. I have checked the wiring to the module and it seems fine . I know the module is working as the Shuttle Example worked . Has any one have an Idea what I may have done wrong. Thanks Frank
