Yes and it will just work. You don't usually need to do anything.
I got this one last year from Mark and just turned it on. Works with the old blue one no problem.
The black wire is an aerial because I got the long range radio transmitter in the black one..
The reason I say 'usually' is because you can set up your base station and Navigators on 4 different frequencies so that you don't interfere with your close neighbour who just happens to have a Massoth setup. I wont go into the setup here because you probably wont need it but its easy - just ask.
