Gizzy
Have you connected the decoder to a point for programming?Today we have been trying to do the railways points using the Massoth Decoders I bought last month. The first one has gone fine, as it is pre programmed 1-2-3-4, and all the points work fine off it.
1 = POINT
2= POINT
3= POINT
4= SPARE
Trying to do the second decoder has not worked, I cannot follow or understand the instructions, but have tried, each time it says 'succesful' on the Central Station, but upon getting it wired to the points downstairs it does not work. In this case, what I want to be output 5 on the second decoder.
But when I press to control switch 1 (off the 1st decoder), what I want to be number 5 (on the second decoder) operates at the same time as number 1 on the first decoder.
Please help, in idiots English, when you can. Confused, and I have followed the central station instructions
I understand that it might need a 'load' before you can do so....
