I have a Fleischmann H0 loco equipped with Esu Loksound decoder, but no sound is coming. The loco runs perfectly and the lights are working correctly too. I don't have the decoder manual and, since the loco came new with the decoder, I have gone through Esu's website. It was purchased in 2003 and I assume it is a V-3 decoder. (I am using my Massoth Central Unit with the Navigator on the programming track).
The problem is that I don't know which CV's should be checked and which values should be assigned. Is there a protection on the cv's, I mean are the cv's locked or can you just modify the value in a cv?
As Greg already mentioned, you need the ESU Installation Manual which is available at their Website esu.eu You should never start messing with CVs on any DCC decoder without first consulting the specific guide for it, other than CV1 Address. If you don't already have it, you should also get the F Key Listing for the installed sound file in the decoder which is also available from the ESU Website's sound file library.
I would not do a reset until you exhaust all other options..........there will be settings changed that will be a real challenge to set correctly without using an ESU LokProgrammer. The LokProgrammer is required to load sound files into decoders, and setting up the decoder such as F Key assignments, dimming the voltage for lights/smoker/other devices, adjusting individual sound levels, changing the individual sound options such as the whistle embedded in the sound file, etc. If you can't get the sound to reactivate after trying all the various settings using a LokProgrammer, the next option would be to reinstall the sound file, but then you'll then need to set up the decoder as a new install such as diming lights, etc. And you'll use that F Key Listing to do so.
