Locomotion Steam Railbus - Getting it going ...
Smart phone - turn location off if you don't want people to know where you are (simple enough to do.............) - just don't attempt to use Google Maps if you have. :)
(And you can be tracked anyway through the towers you connect to - whether it is a smart phone or not - and by your landline unless it is a public phone)
Circling back on this, original owner couldn't find the sight glass but went to a friend and we were able to get the measurements, the original glass was 1/8" od based on the o ring and 1.5" long. The inner diameter of the casing is 1/4". A 3mm tube would also work.
Another friend had a 3/16" tube available so we are going to try and go with that and use some graphite yarn. He said there is less risk of breakage under glass expansion.
Will give it a try and post the fire up results here. Hopefully in a week or two!
