GJFREESTONE
Garden Railways, Model making
hi
thanks to vic and his suggestion of inside cylinders on a lil this is what i have come up with .
first picture this is in its bought state
this is me cutting it about a bit the large dome will be moved forward
bunker put on the back now the dome has been moved forward bell cut off and sand box fitted
foot plate rearranged and side tanks fitted and starting to detail
as you can see all the parts are sprayed with halfords grey primer
mmput back together again blemishes removed and put out side for a test run
grey primer sprayed over any defects electrics added and i like to isolate the engine with a switch
everything in good order waiting for its top coat and detailing does anyboby have a idea on its colour black, green or brown
thanks again to the forum for the insperation
graham shrewsbury
graham shrewsbury
