LGB new to this DCC help?
It certainly is, so don't get dispondent when it all seems too complicated. :nerd:
Right:
12A look at the rating of the kit you presently have..
Re-read the bit about smoke and teeth-gnashing.
Now set the output current on the CS to the lowest figure you can.
Connect a bit of track. Get a loco running, and look at the display on the CS. - One of those figure is the current being drawn.
It will go up a little when the loco is moving, but not by a great deal. - The electronics is running whether you are stationary or not. If you have a long train of heavy stock, then yes, the power needed to move it will be more, and you will see a greater increase in the current being used.
Accessories:
DC..
LEDs are DC. Motors are DC. Anything NOT running from the DCC system will (98%) be DC.
Most things will have come from hobby/00 backgrounds, so 12V should be more than enough.
You can drop this locally, if the accessory needs it.
I would run three pairs of wires:
One pair to the track. - Connect at the nearest point, and continue the cable to the farthest point. Connect the track there as well.
Second pair:
This is also from the Track output of the CS. Both this and the track pair have their own Off/On switch.
Why?
The second pair feeds the point decoders and anything else not track-related.
Two reasons for this:
1. Your points etc sit outside 24/7/365. If anything is going to go faulty it will be this.. Being able to isolate the points etc means you can still run trains AND you know the fault is not anywhere on the track.
2. Should you get a live steam loco (or have one visit) you can turn the track-power off (many live steam do not have insulated wheels, so will short your track. But, you can still control the points.
These two pairs (before their switches) connect together and the track-power output of your CS.
Third pair:
This is your DC (old laptop supply, whatever) pair..
This feeds lights, powers the windmill, whatever you want.
Totally separate to the DCC system, can be on in the rain, in the evening, at Christmas...
This is a great document that clears up some key points to me.
I will have soon two lift out bridges.
Found great brass ball catches that will allow a great connection and align the track heads.
So I guess given I only have x4 turnouts to start with maybe run the Massoth 8156001 Dimax controller through the track?
As I’m assuming it allows the information from the CS to be sent?
Or if I do send a bus of two wires to make it independent from the track as there another feed on the CS for this so my Navigator will be able to send the info?
Sorry.
LIGHTS.
Defo seperate bus with x2 cables.
However I guess this will have to be in the floor under the bridges as connecting it via the bridge could be an arse.
Good idea though as you say just the lights can be on if we aren’t running.
Although I do love our carriage and caboose lights and smoke.
So I probably need a variable DC feed to that I think about £35
As I did get AC to 5DC transformer thing to drop power from the track.
But I think you are right make it seperate.
So thoughts on x4 points from track eek
Or as you advise seperate bus which again would have to pass at floor level by the bridges or bridge if I just send it down one side. I presume I don’t need a loop as cowboy town is furthest away and the Indians gaff is on the way.
TBH. I am very excited about giving this a crack with the new second hand 1200z
Just got my LGB transformer back so I guess I either use it for lights or maybe best selling it with MTS and moving on.
Well exciting times Mr Phil.
No doubt will improve my soldering
Chris
Hi
Quick idiot question.
On the CS are a few outlets as green phone type sockets.
I will read but is this where you can feed the track and seperate to point decoders so it’s all coming back to your handset?
Programming sounds like a fun fest of learning. Esp on point decoders but it also looks like so much more feed back on where you are up to as you go x
Watched summit railway utube seemed fairly clear.
Surprised actually there aren’t more information videos.
Thanks
Chris
The green 6-way connector on the BACK of the 1200Z box is where you connect the cables to the main track and separate programming track.
The rows of phone-type sockets (4 each on front and back of the box, I think) are where you plug in the Navigator handset cables, and/or the cable to the R/C receiver module. Any of these can go into any of the sockets, front or back, they are all connected in a bus.
