You can (read should!) check and alter the limit of current your system can supply before it shuts off the power..
5 Amps should be plenty for your setup.
The Central Station (the big box, known as the CS) is quite clever, and you can set the output track voltage and current.
You are correct, that your devices will only take the current they need..
But, if the CS is set to 12 Amps, and you have a fault, that 12 Amps will happily make things toasty and let the magic-smoke out in abundance. - This causes much wailing, gnashing of teeth, and tends to drain the 'train fund'.
Regarding points..
Yes, you can control these from the Navigator handset.
Accessories..
Yes, you can use a feed from the track for these, but it means your CS (expensive, computery-thing) has to be switched on, if you' just' want the lights on in the garden.
Personally, I would run another cable, from your old MTS supply (or even a redundant laptop supply) and use this for lights and accessories around the garden.
This also means when the roof leaks, and water gets into the lighting system, it doesn't shutdown / damage your CS, so you can still run trains.
Fault-finding is easier if you can keep system separate.
Others may disagree, of course.
