LGB 70255 Digital Starter Set Loco Parallel Compatibility
Big Trak
22 May 2021
43
1
UK
Does anyone know if the black and yellow loco’s in the LGB 70255 / 72255 Digital Starter Set are compatible with parallel digital controllers?
The 70255 set was supplied with a Serial central station and controller but I think I’m going to have to upgrade to a Parallel system in the near future.
Brixham
27 Aug 2010
1,495
120
I have the yellow diesel, and it seems to be fine on a parallel system. However, it only has two function, zero for directional headlights, and ‘one’ for the alternating flashing lights on the roof.
I seem to remember a club member having the steamer, and not having problems with the directional lights.
Malcolm
dutchelm
176
N Somerset
Both locos are fitted with LGB "onboard" decoders, suitable for serial & parallel control.
Gizzy
36,181
2,289
63
Cambridgeshire
I used to have one of these, and it worked fine on my MTS II with Parallel commands.
I sold it on to raise funds for the similar looking LGB 21900 DUO loco, which I use for shunting on my portable Hardyard layout. This one has sounds and MTS controlled couplers.
All the functions work with both the MTS II that I still use with Hardyard, and the Massoth 1200Z I use for the garden line....
Big Trak
22 May 2021
43
1
UK
Thanks for the replies! I’ve just noticed that my set is the LGB 78255 that has an LGB 55005 MTS 2 Central Station. The Central Station has V1.20 underneath it but it’s probably still the Serial version of the Central Station.
Dan
28 Jan 2010
663
52
Eastern MA, USA
All newly MTS locos added to the parallel stations default to serial on first use. You need to hit F and then 9 to activate parallel operation. Doing this a second time reverts you back to serial. Also this needs to be done after changing a loco's address!!!! Non LGB engines can have CV29 changed to allow serial operation, Zimo decoders can do this.
lgbmad
Model trains....G scale mainly, but enjoy all othe
20 Oct 2011
1,146
47
Llanfyllin,Powys
Well I did not know about the F9 switching between serial and parallel……now I know why some of my locos F functions scroll through in serial Mode.
kev
Big Trak
22 May 2021
43
1
UK
Got an email from Massoth:
“only from V2.0 onwards is the control panel capable of running parallel.”
Unfortunately, the old MTS Serial components cannot be upgraded to Parallel anymore as the parts are no longer available, though I did ask what the Serial to Parallel upgrade involved:
“the data transfer has been changed (faster transmission). Hardware has not been changed in either case. The brain is all in the headquarters.”
