I have never used one of these. However, I may be from here on. My question is, how do they work with the switch drives that have no little offset with a hole, on the throw bar?
Madman said:Gizzy, if it is not too much trouble, a photo would be helpful.
Madman said:Gizzy, so the throw bar must be the extra part that is included with a new lantern?
minimans said:How do these work for you? I tried them on my line at one time and I could never get the points to throw 100% which when using EPL automation is a bit of a problem so I took them all off......................Paul
steve parberry said:It is just the little bit of plastic that Gizzy has circled red that is supplied with new lamps, this then clips onto the existing throw bar depending on what side you want to mount it....
