Laying track......
stockers
3,795
66
Nr. Ashford, Kent. England.
So can decking. Actually, decking IS tanalised timber but with grooves machined into it. Usually, the producers of decking select pretty good timber so decking is often as stable a material as wood ever will be.
puffer
27 Dec 2009
42
Herefordshire
I agree with stockers, i use tanalised timber and decking every other day and the decking would be my first choice.
Markrob Meister
24 Jan 2011
12
Thanks Stockers.
So it looks like it's going to be decking.
Markrob Meister
24 Jan 2011
12
Thanks.
I'm going with the decking.
tramcar trev
22 Jan 2011
11,577
8
Canberra, Australia
trevs-tramway.blogspot.com
Here is my sketch of my improved track laying jig. As can be seen it allows me to solder a piece of brass strip alongside the running rail to create "grooved" rail and as the sections where I'll use this technique will be paved with either setts, hardwood blocks or apsphalt it should look reasonable from above, the groove will also be live so that will help with the conductivity....
I will have to have the brass strip cut from sheet. Maybe if I invested in a thiner slitting saw I could use .8 thickness....
I'm thinking at this stage that I'll tin the sections of sleeper where the track will sit and then just flux the underside of the track and heat it to sweat it into position. Ideas? thoughts?
