Having just got everything finally sorted on my K-27 battery conversion - thanks to all here and Steve at Fosworks (more on that elsewhere shortly) my venerable (16 year old) Aristo 5471/3 Train Engineer combo seems to be having problems. I noted when I was doing an "off-line" polarity test for the K-27's rear light (I wanted a power supply independent of the on-board batteries) that the voltage on the leads would not drop or vary from 8.5 or 16.9 volts (see below) on either the slow/fast or emergency stop control buttons on the 5473 transmitter. It would respond to reverse polarity comands though. I have checked the following -
Battery power in tx - ok.
Fuse in rx ok and power and reciver LEDs ok.
Tried both Linear and PWM output settings.
Re-bound tx to rx on different channel (changed from #2-4).
Noted reliable operation of LED (blink) on tx & rx to all commands from tx.
Noted rx responds to voltage polarity command from tx. Confirmed by multi-meter reading.
No responce to voltage control or emergency stop commands despite rx LED blinking in responce to a command from tx. Just fixed at voltages shown below.
Shows a fixed track voltage being outputted at rx's terminals at all time dependent on voltage output settings on Crest 55465 - see below.
Tx led flashes once when each command button is pressed, correct channel selected.
Tx DIRection LED light sequence operates correctly dependent on polarity.
Tx SPeeD LED light sequence does not operate despite rx outputting a track of voltage 16.9 on Crest's 22V setting and 8.5 oon 13.8 setting - could this be a big clue ?
Checked tx's ariel was good and made sure there was a separation of over 3ft between tx & rx.
Opened up both tx & rx to make sure all was clean with no obvious damage, breakages.or debris.
I think that is everything. The only thing I haven't done is attach a loco to it (have rollers) for the obvious reasons. Any thoughts or am I looking at finding a new way to cotrol my track powered locos. My hassels never seem to end. Finally fix one thing, with lots of great advise and support from that army known as "Centalistas" and something else bites my bum . Max
