Gerard
In addition to Phils2um's excellent advice i can add that you can use two rail joiners to connect your power lines to the rails.
You only have to solder two flat ring type connectors to the two power wires and then put them under one of the screws of the joiner.
I think you have had enough advice now in these 101 replys, so be serious and first bring all the good advice in practice and start doing your job and do your next reply in here after you have done your job. Good luck!
