So, basically, garage doors are portals to other dimensions?and exit the garage through a portal to the railway.
Huh, most mortals have to make do with a crummy old wardrobe for that sort of thingSo, basically, garage doors are portals to other dimensions?
Well... in that theme, it's not a wardrobe but talking of portals to other worlds, this is how we access the garage....Huh, most mortals have to make do with a crummy old wardrobe for that sort of thing
Don't got no garage, nor even a carport, so I guess I'm stuck with being one-dimensionalSo, basically, garage doors are portals to other dimensions?
Well, look at it this way, your efforts and attentions can be applied to perfecting that one dimension instead of being divides and pulled hither and yon through multiple dimensions.I'm stuck with being one-dimensional
But don't you have a basement? We all know they're the entrance to the underworldDon't got no garage, nor even a carport, so I guess I'm stuck with being one-dimensional
Beelzebub barred the gate on t'other side. Muttered something about not needing the competition.But don't you have a basement? We all know they're the entrance to the underworld
Burnt out, and not a faun to be seenWell, at least it means there is a light in the back of the wardrobe!
I wouldn't worry about the faun, it's the bloody great beaver you need to watchBurnt out, and not a faun to be seen
Blimey if Nepean is your local......Thought that was my local!
Be interested to know a little more about the bookshelf. Was it present when you moved in or did you build iy. I assume some very good strong casters are on the base with good strong hinges to the left wall. Other than that I assume construction not too tricky though keeping the floor unmarked where the door wheels in an ark would be a requirement for such a thing if it were to hide a secret location. Lots of vids of these things on YouTube but not found any with construction tips as yet.Well... in that theme, it's not a wardrobe but talking of portals to other worlds, this is how we access the garage....
Yes please, always had a mind to do something like this. Makes a great place to keep valuable things securely in a house, better than a safe.We had it built during the renovations. When the wall to the left was built we had a vertical brace put in. We then used hidden hinges (x3 at the pivot point). There are 2 caster wheels underneath. The one at the far end is a fraction lower and takes most of the weight (the floor isn't perfectly even).
The book pivots forward at the front and pulls on a steel wire that runs vertically back and then 90o round a metal bar and pulls a latch behind that keeps it closed. I cam make a video if it helps visualise it more?
It does mark the wood floor but mostly with dust. Rubbing it with a web cloth almost completely removes the marks.
