tim stevens
Hi. I have just reconverted my LGB Spreewald from Battery back to DC/MTS. As usual this wasn't without its problems. Having removed the batteries and motor controller from the cab I managed to pull off the wires that are connected to bulbs that light up the single rear light at the back of the cab and the light inside the cab. I also reinstalled the plunger pickups, unaware that this could be done without removing the chassis and ended up getting very conused as to the position of the pick up springs (which connect the six wheels for the plunger pickups, and the motor pickup wires (which connect to a 4 pin sockit). In the end I used the 2 long wires on the exterior attached directly to the axle and the 2 short ones on the interior ( god knows what they do but I suspect it is something to do with the plunger pickup!). The explosion diagrams provided by LGB are next to useless and rather frustrating. I then did a quick solder to reattach the light wires and found that my locomotive will not run properly in reverse (1/4 speed at best) but was fine going forward. Also the switch inside the cab seems to be doing the same thing regardless of its settting. Can anyone help. I have now disconnected the cab and wires and the problem still persists. I am pulling my hair out and quite honstly I dont have a lot left. Hope someone out there can help.
![IMG_20170111_153732100[1].jpg IMG_20170111_153732100[1].jpg](https://cdn.gscalecentral.net/attachments/79/79075-2c57d01dee29a65782fae24214c60939.jpg?hash=LFfQHe4ppl)
![IMG_20170111_154336030[1].jpg IMG_20170111_154336030[1].jpg](https://cdn.gscalecentral.net/attachments/79/79076-9345f25885b1e9609f8074a22823ced8.jpg?hash=k0XyWIWx6W)
![IMG_20170111_154343150[1].jpg IMG_20170111_154343150[1].jpg](https://cdn.gscalecentral.net/attachments/79/79077-6bebf6e23d5ce1548f4b77210d1d26b2.jpg?hash=a-v24j1c4V)
![IMG_20170111_170859965[1].jpg IMG_20170111_170859965[1].jpg](https://cdn.gscalecentral.net/attachments/79/79078-a5b5607de978827e5a94be6adcad2705.jpg?hash=pbVgfel4gn)
