G SCALE DOODLEBUG WANTED
  • Thread starter paul delany
  • Start date
P
paul delany
30 Mar 2018
44
Dublin Ireland
HI FOLKS WOULD ANYONE HAVE A ARISTOCRAFT G SCALE DOODLEBUG FOR SALE PLEASE
P
Paradise
28 Jan 2010
668
66
I can't recall such a beast in G scale by Bachmann. Are you sure you don't mean Hartland's Rail Motor Car or Doozie Rail Bus. I believe they are 1:24 scale.
Rail Motor Car
Doozie
AristoCraft made a similar looking Doozie and a Gas Electric Rail Car in 1:29 scale.
P
paul delany
30 Mar 2018
44
Dublin Ireland
Rail Motor Car
Doozie
P
paul delany
30 Mar 2018
44
Dublin Ireland
YOU ARE ABSOLUTELY CORRECT I MENT AN ARISTOCRAFT OFCOURSE THANKYOU FOR CORRECTING ME
P
Paradise
28 Jan 2010
668
66
Aha! Yes, the AristoCraft Gas Electric Rail Car is the true doodlebug, usually a bigger beast than a rail bus. Good luck! :)
Madman
Madman
198
Pennsylvania, USA
Personally, I like the Hartland rails a bit more than the Aristocraft model. It's smaller and looks more better with other large scale stock. If you decide on any rails and your search leads you toward the Hartland, don't confuse it with the Delton Doozie. The Delton Doozie is the basis for the Hartland model. When Delton went out of business, Hartland obtained their tooling and reissued the rails under the Hartland name. The motor block was redesigned and is much improved over the earlier Delton design. The Delton motor block has only one powered axle as opposed to the Hartland which has both axles powered.
If you find a Delton Doozie you can contact Hartland and they will sell you a motor block with instructions on how to do the switch. The fellow I spoke to at Hartland, when I did one a few years ago, was very helpful.
Brixham
Brixham
27 Aug 2010
1,139
2
After the server issue....here we go again...
here's a doodlebug...missing marker lights and has been 'rewired', picks up track power only from motor bogie, trailing bogie has non aristo metal wheels.
Sliding door is now back in it's frames. Couplings also 'modified', all done by previous owner(s). No original box
P
paul delany
30 Mar 2018
44
Dublin Ireland
hello there in case you didn't see my last message to you I will take the caboose from you for 125 payday two weeks away if that's cool with you
Paul d
Brixham
Brixham
27 Aug 2010
1,139
2
PM sent
M
Brixham
Brixham
27 Aug 2010
1,139
2
here's some pix....bloomin camera is playing up again...
Brixham
Brixham
27 Aug 2010
1,139
2
and another
Brixham
Brixham
27 Aug 2010
1,139
2
and a third
Brixham
Brixham
27 Aug 2010
1,139
2
last one
Brixham
Brixham
27 Aug 2010
1,139
2
Brixham
Brixham
27 Aug 2010
1,139
2
Brixham
Brixham
27 Aug 2010
1,139
2
Brixham
Brixham
27 Aug 2010
1,139
2
have looked in a few places for the spare aristo marker lights I have stashed somewhere...there's a likely box right at the bottom in my shed....may take a while to excavate to that!
Malcolm
