I've been making the most of the weather over the last couple of days and put together a short video showing how I operate a typical pick-up goods train on my railway. Hope you enjoy .......
Rik
PS - No music this time, Alan
Superb Rik, many of us that do run like you will appreciate the time you have taken explaining what is occuring. I wish that I could use your labelling system, would make things much easier for my guest running teams. However my line goes around a loop part way and they would be lost to view at Lindenburg and Stiegge Stations. Great pity as it is a superb system and so much like was used on the real thing.
In the past on my old line I used to use Coloured Map Pins as a quick reminder each station having a different Colour with that being reflected on the Station Name Boards. The pins went into small holes in the buffers, many of my Wagons and even Locomotives show up these holes to the wonder pf visitors. I also used the holes for a Tail Lamp. But I am now using Magnetic Wagon Cards of Credit Card Size with Waybills that fit into a pocket on the card. Works quite well but still get errors! But it is fun the day after to sort out the problems left behind when they have gone home! Tail lamps are Map Hooks that hang onto the rear of the last wagon and mostly get moved on during shunting or reversal of direction, but sometimes get forgotten to the chagrin of the line Superintendent.
I wonder how the rules of Single Line Working Operate on your line, does each Station have a Box with communication and Token Working or do you run with Staff and Ticket as the SR did? I expect you have explained it all in your Blog, must have a look.
Mine works on Train Order as is the norm in German NG Lines with Trains Timetabled to pass at locations with no variance. Quite how they sort out problems of severe late running in East Germany I am not sure, but each Station had in the 80's an SM and phone communication so I expect things were sorted out between them with new (revised) orders being given to the Train Crew.
