muns said:
			Hey Phil,
 Any progress on this.  I am particually interested in the position of the reed switches and magnets.
 Oh, and please can you detail the commands you used for the central station programming
 Ta
 Sorry Mark about delay in posting details of programming, but here goes
 The same as the shuttle programe
 >I.E M3 then M1 and scroll down to Auto prog. M2 to OK
 Then M1 to auto drive confirm with M2 then enter switch(reed)no, In my case because I have the rack on 1 & 2 I chose 3 confirm with M2. Then enter contact number 2b . OK on M2
 Loco number your choice, confirm M2. Command 3 confirm M2  then delay your choice..
 Thengo through the next stege the same only entering 4 as the number and 2A as contact number. Scroll to end using M1 M2 entering your numbers
 Then after the delay time press M2 again at this point the curser goes back to number here press 3 confirm on M2 that should then go to contact at this point  press the right arrow.
 This then goes back to number enter 4 then Ok on M2 that should take you to contact here press the right arrow then M3 to loco number turn the control knob to the desired speed. Once happy with speed exit to another loco number
 Hope this helps
 Note the limit switches are in the roof of the station and make contact with the beam
