I have an older version track powered Accucraft K-27, the one with the right rail pickups only on the 4 tender wheels and the left likewise on that side's 4 driving wheels only. The loco has a functioning Sierra Soundtraxx sound card fitted. Most sounds are voltage activated but the chuff and a couple of other sounds are reed switch activated.
I have the published manuals for both the loco and the sound card. The sound card's has a full wiring diagram but the loco does not. I have searched the web for the latter but to no avail. I did find an article, authored by Tony Walsham of this parish, but it is not clear as to how he (re)arranged the power supply to the motor and isolated the pickups on this specific loco type when doing a similar conversion some years ago.
As I understand it replacing the track pickups' voltage inputs to the sound card is fairly simple - replace input from track pickups with those from one of the 2 pairs from the esc. What I am not sure about is how to isolate the motor (and possibly chassis too) from track induced voltage inputs and how best to attach the esc voltage input to the motor. There is a terminal block accessible under the ashpan where a number of wires coalesce for power distribution on the loco itself.
Questions - Am I right in the assumptions I have made so far and how do I isolate the track pickups on the loco (tender is self evident) and connect the motor to the esc without ripping the loco to bits ? Your assistance and suggestions would be most welcome.
A picture showing the terminal block under the loco's ashpan. As a point of note I have acquired all the conversion gubbins from Fosworks - A Cobra high frequency 6 - 24v speed controller, 14 cell AA NiMH battery pack with 5 amp fuse, Omni Tx-2.0 tramsmitter, Omni RX-2H receiver and assorted other parts for charging and wiring. Max
