colour light signals
hornbeam
1,881
Hi all,
I?m looking at building some colour light signals that I want to be run automatically much like you can do with the LGB ones. I?m having a few thoughts at the moment for the heads. I may build ?searchlight? heads myself with multi colour LED?s, using a washer for the main head body- unsure about how to build the hood. I may opt for the Gaugemaster Hornby type signal. I?m planning on using a peco point motor with a micro switch to change the aspect from reed switches in the track., the motor housed in a plastic box from Maplins which will be made to look like a line side equipment box.
However i?m aware Martins models used to make colour light signals, do they still do them, has anyone bought some and if so do they have pictures?
mike
Master at annoying..
4,457
Rossendale
malcom (pbm) told me A nice trick..
use the large choclotale block conecters (b+Q ewct) re move the brass guts, use the nylion seath.. a small led fits in nice, and you can carve the nyloin hood to shape.. cheap byroe pens for the tube..
Glengrant
11
NE Scotlamd
Well of course this became a very extensive project in the old forum, developing out of Mike's brilliant ideas at the very beginning. Eventually several contributors came in with their own ideas, myself included, and really the whole thing really took off. I eventually gave up the plastic tubes, anyone want to buy a ballpoint pen insert, and used a brass tube, several of which were kindly supplied by ??????, I regret to say I have forgotten. I also gave up on the terminal block inserts, and when I resume my col light system, I will be using inserts which are designed to hold LEDs. Two of these are used on my snowplough lights. One of us deals in these inserts. I wish everything that was written about this project could be put together, it would make good reading, and full of brilliant ideas.
The LEDs here are fitted into inserts, then I put the whole thing into a loco lamp, but of course it could easily go into the signal post
Neil Robinson
579
N W Leicestershire
images
images
images
This is the topic mentioned above.
http://www.gscalecentral.net/tm?m=1223&high=colour+light < Link To http://www.gscalecentral....&high=colour+light
Glengrant
11
NE Scotlamd
Neil Robinson said:
Well done Neil, but of course it went on from there. I regretably have forgotten some important names, and I hope I am not treading on anyone's toes if I reproduce this brilliant bit of work which one of you psted, and which I endeavoured to copy.
Bram
Playing trains, Ballroom Dancing, Good Food & Wine
4
Knowle
Now thats a useful diagram, thanks for posting
nicebutdim
14 Dec 2009
4,694
16
Sunny Surrey (Ha)
With regards to the relay, don't use peco motors with the clip on switches, it's way too expensive and you'll burn out the reed switches. Maplin sell latching relays that have two coils and dpdt contacts (item http://www.maplin.co.uk/Module?ModuleNo=37529 ), they are ideal, I use them to control my signals.
hornbeam
1,881
cheers, will give them a go. cant believe I didnt think of using relays!
Glengrant
11
NE Scotlamd
It wasn't mine originally Bram, I have a feeling the author may have given it to me as a PM, I just can't remember, but yes, it is a very useful diagram, is the guilty party reading this?
Steve
I didn’t say it was your fault, I said I was b
1 Jan 1970
29,027
285
D.I.L.L.I.G.A.F
You have two options throught the track or a switch box if you wish them to change colour
Philbahn
3
74
Swinton Manchester
Heres my offering.
RHB. After seeing Paul RHB's layout at Warley show thought i would have a go at improving my signals
Philbahn
3
74
Swinton Manchester
Though not finished it gives you the idea
Philbahn
3
74
Swinton Manchester
dumpy
8 Nov 2009
439
1
Threshfield, nr Skipton
ROSS said:
I believe Kalmbach produce a booklet of electronics with circuit DIY drawings in it for various model rail applications..one of which is a complete signalling set up. I think its called Electronics for Model Railroaders.
My contribution to this thread is to just to add my experience.
First. I take my hat off to those who like spending time making fiddly little things.
I went to http://www.modelpower.com/ who sell... relay as suggested somewhere in this thread.
