CharlieBear
Thinking of investing in some LGB tram type catenary, now the wires are 680mm long has anyone experience can the arms be spaced that far apart (on straight track) without too much movement when the loco passes? obviously on bends they will be much closer.
Also does the overhead wire attach to the arm using connector clips or just bnd the wire? If anyone has a closeup picture please? I suspect the clips are only for use with the modern RhB style masts?
Thanks in advance
Thanks in advance
