It is often stated here on this great forum that R1s are being used because its cheaper. Not necessarily so.
Agreed - if space is tight R1s allow one to build a railway in that small space. We have LGB to thank for that.
However, using R1s for the sake of it hardly adds up.
This plan uses 12 R1 curves AND 16 short straights.
OR 16 R3 curves.
Using Dragons pricing - thats £ 165.64 for the R1 circle and £ 179.59 the R3. Just £14 more and stock looks and runs better.
As for pointwork.
An R1 turnout has two tracks totalling about 600mm
an R3 has two tracks totalling about 900mm
To make a comparison I will use the powered turnouts to keep everything else the same. R1s are £53.06 and R3s £71.44. Seeing as an R3 is half as long again as an R1 it works out about £8 cheaper.
So- come on folkes. If you have room go for R3s (or bigger). Even if you have a stash of R1s in the cupboard the e-bay price is often above the new price - so sell them.
That should set up a healthy Sunday evening discussion.
OR 16 R3 curves.
As for pointwork.
