R5 going into R3 in front of the loco:
looking the other way with a similar transition from R5 to R3:
If you really want to operate your R3s without motor then they are easily detached and you'll find a ready market to sell the motors on - try here for starters and I reckon you'll have your hand bitten off within minutes of offering. Alan's quite right about costs and so are others that comment that R1 points often come up really cheap - and there's a really good reason for that. If you can fit R3 or bigger then my advice is to do so, you won't regret it. If you can't, then sell up and buy a bigger garden!Gizzy said:One thing to note, was that there was a shortage of the LGB R3 points a few years ago, which meant that many had to search high and low to find them. They became rare beasts, but now there are the options of the Piko R5 and the Train-Line product, as well as the LGB R3 point. There are also options available from USAT and ART and the more bespoke products.
However, this recent shortage of LGB R3 has forced many of us to use the LGB or ART R1 point.
Also, LGB R3 points come with a motor as standard, whereas you have the option of purchasing an R1 point with or without the motor. This is something that one starting out might want to consider.
In my case, I started with manual points, and then fitted motors as I could afford them. With around 30 points on my railway, I have only motored the facing points at the moment and left trailing points to work on spring action....
Its green cambrian granite chippings from the local garden centre. Approx size is 5mm to dust. I seive out the largest bits as they are alot larger than most of the stuff in the bag.jameshilton said:Wonderful Doug, that's what I'm hoping to achieve in some locations!
What have you used for ballast in those photos?
Good point, well made BB....Bredebahn said:If you really want to operate your R3s without motor then they are easily detached and you'll find a ready market to sell the motors on - try here for starters and I reckon you'll have your hand bitten off within minutes of offering. Alan's quite right about costs and so are others that comment that R1 points often come up really cheap - and there's a really good reason for that. If you can fit R3 or bigger then my advice is to do so, you won't regret it. If you can't, then sell up and buy a bigger garden!Gizzy said:One thing to note, was that there was a shortage of the LGB R3 points a few years ago, which meant that many had to search high and low to find them. They became rare beasts, but now there are the options of the Piko R5 and the Train-Line product, as well as the LGB R3 point. There are also options available from USAT and ART and the more bespoke products.
My own opinion is that PIKO have a much better track geometry than LGB, whilst still maintaining compatibilty with them.Deutsche Reichsbahn said:If you need R3 points without motor, buy PIKO! Lot cheaper.
BUT keep in mind LGB R3 and PIKO R5 differ a bit.
CoggesRailway said:So LGB R5 and R3 are made to look right when paralell? Didn't realise it worked like that!
themole said:R1 curves can be straightened, just remove the brass lip on the fishplate that locates in the plastic sleeper. Then, with care, remove the rail from the sleeper web, the rail should slide out. Repeat with the other rail. If doing say, half a circle, you will have six long rails, and six smaller rails. KEEP The sleepers and webbing. Now straighten the long rails carefully in the vice. Repeat with the smaller rails. Now the sleepers and webbing. The end sleeper will have a slot for the fishplate brass lip slot. Now fit a new fish plate or use the existing fishplate; slide the sleepers back on, but turn each sleeper 180* to even out the curve, or remove totally the webbing. Then slide the other rail of the same length, on to the other end of the sleeper and fit fish plate. When finished you will have three small straights and three longer straights. Job done! Now have a brew! Alyn
why hide them?3Valve said:Yep I'm thinking of straightening out my surplus R1s and installing them as straights behind the tree line on the new railway, that way it wont look so obvious that they're straightened out R1s
