6 wheel motor block for a 0-6-0 Steam engine
musket the dog
31 Oct 2009
787
143
Leicester
nlrr.webs.com
....Single reduction drives, of which there are a few readily available, are OK until you want to haul heavy loads, then you need to go to 2-stage gearboxes which, for the devout bodger like me, means coughing up and buying one.
It took quite a bit of looking to find the supplier that eventually got me the worm gear and the coupling to go from the motor's 2.3mm shaft to a 3mm axle.
My plan-B involved a como drill gearbox coupled to a set of reducing bevel gears, but I think then it would have taken off like an absolute snail
Rhinochugger
Retired Oik
4,243
North West Norfolk
Yes, the Como gearhead motors are another route, but you need to use 1:1 bevel gears .................... with the right bore combination for motor and axle :oops::oops::oops:
LGB-Sid
19 Sep 2016
2,036
1,130
65
UK
I had been thinking if I'm going to build / print the Loco I could print the drive housing etc. and buy the wheels etc, but thats just making life even harder :) I want 6 wheels for power pickups at least, that's one reason I decided not to use a 4 wheel box which is easy get get even an LGB one new. The staniz I have run OK, until they stall on points :( which is annoying at least with six wheels picking up power its harder to stall them on points. Maybe I should just convert to the dark arts and go battery power :devil::devil:
Thanks for all the comments / suggestions so far.
3,525
Might be worth talking to the likes of PDF Models? - They advertise custom chassis design and print??
