Sounds like a good plan, seen lots of different tips on how to get proper adhesion between the material and a cold print bed. I suspect it's one of those problems that only really solved in the long run by trying several ideas until you find one that works. Would the blue painters tape just be the single sided masking stuff? I've used double sided sticky tape before but it's a nightmare to clean off of the print bed afterwards.
Mine has a heated bed but even at 110 deg ABS can still warp and lift off the bed the scotch blue printers tape is just sticky on one side the idea behind it is it gives a key to the glass surface , in theory. The good thing about it it holds fast up to 110 deg dosen't bubble of lift off the glass and when you need to pull it off it comes off clean. I used it as in theory on it's own at the right temp ABS will stick to it which some of my bits have but large foot print objects don't stick enough to stop the wrap at the edge and lift, so it's cheap hairspray and ABS juice testing this week, the glue stick theory didn't work at all it made adhesion worst
