Nemo
One cold March day at home I was at a bit of a loose end and was looking at my LGB stock and wondering about how I could make something a little different. I have quite a bit of German Saxon themed stock including 6 bogie coaches and 3 x IVk loco's and a IK (wonky) loco. Then I thought about something historic, can I make something to run as an historic coach. About the same time Wayne Haste (off this forum) posted some pictures of some builds of stock that he had completed and they looked great, this really inspired me to have a go.
So a rather nice LGB coach was selected
and within 5 minutes it looked like this
And this is the bit I intended to replace, so after some careful measuring and head scratching I started to mark out some foamboard that I had spare.
Window's were drawn and cut, I've quickly found out that when using a sharp knife, it pays to keep your fingers out of the way. Also its more accurate not to try and cut through in one cut but to do several lighter cuts until you get through.
Wooden panelling was scribed on using a flat bladed screwdriver at 5mm intervals. After cutting out the ends and the other side and floor, then construction commenced. Weights were used whilst the glue went off.
After a few days the body was looking like it should do and a trial dry run was done.
