Zimo Mx696 sound issue
gn13565
9 Aug 2011
28
1
Hi
Help…
I’m stumped
I’ve got an Zimo mx696 decoder (I’ve got other Mx696s working fine) I cannot get any sound out of it.
I’ve loaded the sound project, the load completed successfully. I can drive the loco, but no sound.
I’ve tried a different sound file and the same result.
anybody got any hints/tips or debugging advice?
many thanks
3,437
Simple things first:
F8 - As stated above..
Speaker - Wiring, or faulty speaker.
Soundfile - Load a different one and try it.
gn13565
9 Aug 2011
28
1
Thanks all
1. yes F8 I know about - doesn’t work.
2. Tried a different sound file - no difference no sound
3. Tried another mx696 in the harness- works fine
I’d think it was a faulty decoder, but I can read/ write CVs without issue and projects load without errors.
thanks
Zerogee
Clencher's Bogleman
1,722
North Essex
Thanks all
thanks
Just a thought from a non-expert... could it be faulty, but only in the sound output stage of the decoder? I would assume that in such a case the decoder would look and work fine from the programming point of view, but maybe the bits of gubbins (note the technical terminology there...) that send the sounds to the speaker are duff?
gn13565
9 Aug 2011
28
1
Hi
I spoke with my supplier and that was his take as well. Sending out a replacement.
thanks for all your advice.
greg
Dan
28 Jan 2010
617
48
Eastern MA
Note that CV 395 is max volume, cv 396 is for sound decrease F# and CV 397 is for sound F# for volume increase. CV 366 is no longer used for max volume with these settings. I set 395 to 160, cv 396 to F27 and CV 397 to 28. This gives me F27 for volume decrease and F28 for volume increase. Also there is a volume pot on the MX696S.
