Wiring LGB points, novice need help please.
Shunter46
3 Apr 2019
58
West Midlands United Kingdom
I have to wire up several sets of LGB points ( No 1201/10 point motor) for my layout but I am not sure what I need to do this. I think i need an on-off-on self centring switch ? and a transformer ? If this is correct what type of transformer do I need and what output ? 12v or 18v and what amperage and where can I buy one ?
Any advice and info gratefully received.Thank you.
Gizzy
34,168
1,756
60
Cambridgeshire
You will need a suitable AC supply of around 18V, 1a or 0.5A will do.
You may already have a LGB one with an AC output.
You need AC, but the LGB Switch Units rectify this into DC to move the point motor.
The LGB ones are quite expensive, so I recommend these Gaugemaster switches, which come with diodes and instructions.
Everything you need and you can build them into your own mimic panel as I did before I went to the digital Dark Side....
Shunter46
3 Apr 2019
58
Thanks for the info. May I please ask what the diodes do ?
Gizzy
34,168
1,756
60
Cambridgeshire
The diodes rectify the AC to DC (direct current).
You put a diode on each side of the switch but in a different orientation. The diodes 'rectify' the Alternating Current to a Directional Current.
The point motor is an actual motor which does half a rotation. The diodes change the direction of the current so that the motor operates a half turn either clockwise or counter clockwise, diving a pinion which meshes with a rack that connects to the tie bar of your point....
Greg Elmassian
8 Mar 2014
5,057
708
San Diego
www.elmassian.com
Actually the diodes rectify the AC to pulsating DC...
The pulsating DC allows a higher voltage than constant DC, helps give a bit more "oomph" and also simplifies the type (cost) of the electrical switch needed..
Gizzy
34,168
1,756
60
Cambridgeshire
You are correct Greg,
but I sensed the OP might not be familiar with electronics, and I tried to keep my answer as simple as I could.
Hopefully Shunter46 will keep us posted as to how he gets on....
Shunter46
3 Apr 2019
58
Thanks Guys for the information re wiring LGB points. A couple of switches order so I will let you know how I get on when it’s successful done.
Dan
28 Jan 2010
401
36
Eastern MA
You only need 1 set of diodes to keep the wiring simple. The diode wiring feeds the ends of the DPDT, center off switch and the center feeds the EPL drive.
much simpler wiring!!
ge_rik
1,104
Cheshire
www.riksrailway.blogspot.com
It's not essential you use an AC supply and diodes, a DC supply is perfectly adequate. I switch my LGB point motors with an old 16v DC Scalextric transformer. I originally used momentary DPDT switches .....
..... but I now use a Deltang Transmitter and receiver to trigger relays.
Rik
JimmyB
Rik
Rik, just read your Deltang to trigger points, very interesting, and when i move totally to battery and remove the TE, it is roughly what I am after, though currently it is a little beyond me. I will have to read it a few times, its the Picaxe that I need to get my head around. :)
2,895
Tamworth, Staffs.
Jimmy,
When the time comes..
You can put the Picaxe with my Lump Hammer.. :)
(We have ways of moving your points.. ).
