Bill Barnwell
Need suggestions, installing window glazing on Playmobil windows using clear plastic sheets, the window is a double hung and the lower window will move up and down in front of the upper window, there isn't room for the movable one to move up and down if there is glazing on it. The window will be partially open on some and others will be all the way the open ? is should I put glazing on the top fixed window and just on the part of the lower window that is not in the area of the top window? All suggestions appreciated, Bill
