You could keep boxes in each room of your palatial abode, so you’d always have them to handI am *always* running out of tie-wraps..
Vaguely considering buying by the box....
100 x 2.5mm, black nylon..
Box quantity 55,000!
Perhaps not?
Now, we both know that 'someone' would probably have something to say about that...You could keep boxes in each room of your palatial abode, so you’d always have them to hand
That would be Someone with a capital S. And WMBO.Now, we both know that 'someone' would probably have something to say about that...
but fitting this will require a strip-down of the cab unit -one of those 'one step forward, two steps back' disadvantages of prototyping...
I was talking to Paul at P&S Models some months ago and he told me that Marklin had offered him traction tyres for a particular loco in an enormous quantity.I am *always* running out of tie-wraps..
Perhaps not?
Nice prototypical pot boiler under the bonnet thereAn odd-jobs afternoon in the workshop today. None of the radiators that I looked at -and a couple that I bought- were right, so I (of course...) decided to make an insert for the wooden 'shell' that I made a while ago. First, a piece of brass shim was cut to size, and cleaned:
then heated and 'tinned' with solder. View attachment 363251
I then cut some ¹/16th brass H-section to length and took time placing it on the tinned brass. When I'd got it positioned, I applied heat and sweated the whole thing together:
It was then assembled into the shell and test fitted to the railcar:
The wheels and coupling rods run perfectly, but only in one position -swap them around, and they can bind. I discovered this the hard way last week, stripping the brass drive gear, so after assembling it correctly, I removed each rod and wheel in turn. The chassis already has a number, 1-4, on each corner, so the corresponding con rod and wheel were marked on their rear faces to match:
Which will make things easier when it comes apart for painting and maintenance, etc.
A piece of 3mm plate has been cut to make a pivot plate for the 'carriage' to swing on, View attachment 363255but fitting this will require a strip-down of the cab unit -one of those 'one step forward, two steps back' disadvantages of prototyping...
Finally, a bogie was fettled from a basic Brandbright item, with axle boxes turned up from hexagonal brass bar to add a little detail:View attachment 363268
and then the whole thing was pushed together, which seemed a good point to call it a day...View attachment 363269
The problem with most 'LGB' traction tyres, is all the stock is probably 30 years old.I was talking to Paul at P&S Models some months ago and he told me that Marklin had offered him traction tyres for a particular loco in an enormous quantity.
Nice prototypical pot boiler under the bonnet there![]()
Your skills and ability to improvise leave my quite envious. Remarkable work. I can't wait to see the finished railcar in action.An odd-jobs afternoon in the workshop today. None of the radiators that I looked at -and a couple that I bought- were right, so I (of course...) decided to make an insert for the wooden 'shell' that I made a while ago. First, a piece of brass shim was cut to size, and cleaned:
Caley C2XBusy with bits of 2 jobs today, first off the railcar roof, cut and drilled 4 plates to locate in the top of the doorways with a screw in each.
View attachment 363274View attachment 363275View attachment 363276View attachment 363277
Secondly, the replacement dome arrived, so a quick clean up and a trial fit,
View attachment 363278View attachment 363279
My Cale has 2 humps
Needs a bit of fine tuning and a new method of securing.
My Cale has 2 humps
Like Patrick your skills and dedication to the tasks in hand are remarkable Pete. Again quite envious, in a good motivational way. Another railcar to savour in the near future in its completed form. I suppose with the IoM as your chosen subject matter it comes with the territory.Busy with bits of 2 jobs today, first off the railcar roof, cut and drilled 4 plates to locate in the top of the doorways with a screw in each.
My Cale has 2 humps
Was thinking about your rad last night and a very inivitive job it is, had you pre tinned the U section lightly on the base of the u section it may have made a neater job in the end. I say this not to upset you but perhaps help others that may wish copy the idea. I have certainly bunged it into the ‘if I need a rad’ single brain cell.An odd-jobs afternoon in the workshop today. None of the radiators that I looked at -and a couple that I bought- were right, so I (of course...) decided to make an insert for the wooden 'shell' that I made a while ago. First, a piece of brass shim was cut to size, and cleaned:
