Chris Vernell
Winter is coming
Which is to say we hide the evidence.No photos, we don't show off when we're bodging![]()
Yep with VTP usuallyWhich is to say we hide the evidence.
That looks like an interesjting project, all laser cut at that scale. The set given your me by my father, Xmas 1963, included a Tri-Ang TT consist that was a Bulleid BofB Pacific, 3 green Mk1 coaches, open 2nd, Buffet, Brake and a.......utility (baggage?) van. All in the correct colours. We lived just around the corner from the SR London terminal Viictoria. Yhe consist's significance was totally lost on this then, and probably still, ignorant soul. Until 20 years ago. Before he passed I apologised for my past ignorance. MaxGot brave and finally decided to make a start on my TT120 kits, the brake van bodies were sprayed Halfords red undercoat the other day but the CCT kit needed a thin coat of Green so mixed that up with acrylics today using some Tamiya Acrylic filler, not loosing the very fine detail was the requirement that I think I have managed with. Will get a second probably thiner coat later.View attachment 357936
No worries, TT3 is a very long time ago the Bullied was a MN but I used mine as a WC/BofB on my West Country branch terminus. The van was classed as a Utility Van by Tri-Ang, available in Green and Maroon. All listed in the Ramsay’s guide now sadly nit produced.That looks like an interesjting project, all laser cut at that scale. The set given your me by my father, Xmas 1963, included a Tri-Ang TT consist that was a Bulleid BofB Pacific, 3 green Mk1 coaches, open 2nd, Buffet, Brake and a.......utility (baggage?) van. All in the correct colours. We lived just around the corner from the SR London terminal Viictoria. Yhe consist's significance was totally lost on this then, and probably still, ignorant soul. Until 20 years ago. Before he passed I apologised for my past ignorance. Max
The left hand building looks like it's been pre-weathered!I've started work on my latest building project, which is a bit of a challenge. Some time ago, I bought two Kippo Models resin cast kits of lineside huts, both with tiled sloping roofs, but with different frontages. The idea was to combine the kits together to make one building, a Yard Office/WC/Stores for Goudes Sidings, on the Claptowte Railway. I have several Kippo Models resin kits, and they were always good to put together and fun to modify by adding extra detail. I think these two kits must have been pretty much the end of the line before Kippo Models went over to a new range of models produced by 3D printing in plastic. The new models are a far superior product with better detail and far less work to assemble. I have one of their new lineside kits to make into a smaller yard office for Phidell Yard. I will probably assemble this kit next, so that the painting can be done in tandem.
I think by the time these kits were produced, the moulds must have been coming to the end of life. There was a lot of flash to file off, but this in itself was no big deal and was quick and easy enough to do, also the resin used appears to be a bit of a dogs dinner. The kits had the merit of being cheap. The worst aspect was the tiled roofs, the moulding definition was very poor, I guess the moulds were really tired, and a lot of work was involved re-scribing the outline of the tiles. I'm not sure everyone would have bothered, but I felt it was worth it, as, when finished I should be producing what I hope may be a unique model. Everything is now cleaned up and washed. The pic shows all the parts. less two redundant end walls, where the two kits will be joined. Also not show, are the excellent 3D printed drain pipes and guttering, also from Kippo Models, purchased separately, that I used to good effect on my recent Santa's Grotto Carriage Shed build. The roof ends still need to be squared up before they can be joined together. The biggest challenge will now be to alter the brickwork joints on the front and back walls, so that they can be joined together.
I thought I’d post some imsges of my near complete Y6 GER/LNER/BR tram engine. It awaits cow catchers and a LGB type coupling at one end.Just a few images of something I’m building whilst awaiting bits on another project. At the gauge 3 show I picked up a wooden kit for the body of a GER tram loco. Toby for the TtT bods.
Well amongst the loot I came away with from Llangollen was a playmobile 0-4-0T.
This seemed like an ideal opportunity for a quick build through uniting the two purchases.
The playmobile body has been put aside.
I’ve also dug out a Stainz boiler unit from when I built a GER Y4 tank loco.
This with a little modification will go inside the team engine to represent the actual internal gubbins etc.
Anyway some GER buffers are on order from Walsall models, so I guess it won’t be long before the model moves to completion.
This just leaves the cowcatchers to resolve!?!?!View attachment 357413View attachment 357414
Interesting project. Yes, 3D printing results in every print being a perfect original, from the digital master. Not a degraded 2nd generation copy from a physical master via a mold with a finte life, that some may be tempted to exceed. So long as the print medium is right then these 3D print products are ideal in this market sector. My supplier in Birmingham 25 year ago, CMA (still going), only used polyurethane resin, of the correct type for purpose. More flexible for say a moving loco that's going to get bumped around, more rigid and slightly brittle when fine detail and textures are needed to be captured on a static model. These were vacuum molded to eliminate air bubbles, hence the molds were sealed allowing detail on the reverse of moldings. Finally, dependent on the complexity of the master, under cuts, etc', a strict life of maximum 50 units was placed on their use before replacement. Coincidentally GRS used the same supplier as myself for some of their 16mm locos, L&B and more and rolling stock W&U, WHR and a few others, and lot of the G3 items they made/make. Swift Sixteen do too. All quality stuff. MaxI've started work on my latest building project, which is a bit of a challenge. Some time ago, I bought two Kippo Models resin cast kits of lineside huts, both with tiled sloping roofs, but with different frontages. The idea was to combine the kits together to make one building, a Yard Office/WC/Stores for Goudes Sidings, on the Claptowte Railway. I have several Kippo Models resin kits, and they were always good to put together and fun to modify by adding extra detail. I think these two kits must have been pretty much the end of the line before Kippo Models went over to a new range of models produced by 3D printing in plastic. The new models are a far superior product with better detail and far less work to assemble. I have one of their new lineside kits to make into a smaller yard office for Phidell Yard. I will probably assemble this kit next, so that the painting can be done in tandem.
