Zerogee
Clencher's Bogleman
To all those of you who are experts with a soldering iron, please bear with me a moment.... my soldering skills and experience are very limited, I can usually manage to get a half-decent joint (if not often a pretty one), but I've often had an annoyingly random problem that there must be a VERY simple answer to: sometimes the iron tins up beautifully with just the slightest touch to the solder wire, but other times (within the same work session) the solder is repelled from the iron tip - it melts, but just "retreats" to form a round blob on the end of the solder wire, rather than melting onto the iron tip as it should do..... what is happening here? Does the tip of the iron need cleaning, and if so with what? I've tried wiping it on the cleaning sponge of the iron stand, but that doesn't seem to clear the problem.....
A brief Google of "common soldering problems" brought up masses of info but I haven't yet found a specific answer, so I wondered if anyone here could save me a lot of wading through pages of stuff online....?
Thanks!
Thanks!
