electricity_bill
Does anyone have a UK source for USA Trains track connectors and bolts?
I found these ones by Googling;Does anyone have a UK source for USA Trains track connectors and bolts?
Are you talking about the R80001 rail joiners and R80002 track screws?Does anyone have a UK source for USA Trains track connectors and bolts?
Do you need the 'fishplates' and screws? If so, how many are you after?Does anyone have a UK source for USA Trains track connectors and bolts?
Yes i amAre you talking about the R80001 rail joiners and R80002 track screws?
How many have you got?Do you need the 'fishplates' and screws? If so, how many are you after?
Too expensive to source from USA.I found these ones by Googling;
USA TRAINS G R80006 Screw On Type Power Lead Connector Fits LGB Aristo, Bachmann | eBay UK
USA TRAINS G Scale R80006 Screw On Type Power Lead Connector. ITEM IS NEW AND FULL WARRANTY. Warranty We are an authorized dealer for Bachmann, USA Trains, Soundtraxx and more so the manufacturer warranties are INTACT.www.ebay.co.uk
They look similar to the LGB and Piko versions....
I'll have a look in the morning Bill. I'm pretty sure I put them somewhere safe when I replaced them with Hillman clamps. There may be some Aristo ones too. From memory I think the Aristo jobs were a little longer. I also seem to remember there were some with a 'tongue' that slotted into the final sleeper similar to what you find on the LGB rail joiners so you had to release all the screws on the underside of the track before you could slide the rail back to release the joiners.How many have you got?
Yes, the USA rail joiners have the LGB-style tongue and the Aristo-style screw holes.I'll have a look in the morning Bill. I'm pretty sure I put them somewhere safe when I replaced them with Hillman clamps. There may be some Aristo ones too. From memory I think the Aristo jobs were a little longer. I also seem to remember there were some with a 'tongue' that slotted into the final sleeper similar to what you find on the LGB rail joiners so you had to release all the screws on the underside of the track before you could slide the rail back to release the joiners.
Hi Bill. I've found my box of track fittings. There appear to be three types of the ones you are after. If as Chris Vernall says the USA Train ones are those with a 'tongue' then I have nine. If they are either of the other two variants then I have a reasonable supply. I also have a fair number of the hex headed bolts. Photos below.How many have you got?
Such superb organisation.Hi Bill. I've found my box of track fittings. There appear to be three types of the ones you are after. If as Chris Vernall says the USA Train ones are those with a 'tongue' then I have nine. If they are either of the other two variants then I have a reasonable supply. I also have a fair number of the hex headed bolts. Photos below.
View attachment 320949View attachment 320950View attachment 320951View attachment 320952
