If I remember correctly the standard socket only supports the front/rear lights and possibly smoke function on only one of the arrays of pins. Bachmann may have extended it to support some more functions on the 2nd array of pins.
When I fitted a DG583AR in mine I used the additional plug/socket on the side of the decoder to drive all the lights including the firebox lights etc. The lighting wires all connect to the existing Bachmann main board via header plugs, so I disconnected them from the main board and made a little adapter board between the Bachmann wiring and the decoder, with appropriate resistors.
As Neil says, if you want to revert to DC you'll need the original DC jumper board to replace the decoder. If it's missing you may be able to get one from Bachmann or from someone who doesn't need theirs. (At which point I have to say sorry I need to keep mine!) If I remember correctly, the 2-6-6-2 also came with another adapter board with wiring to allow you to connect to a non- plug-n-play decoder.
[edit]
According to the instructions, one of the switches on the main board controls whether the cab light and firebox are under DC or DCC control. I suspect this either links the lights to the main board voltage regulator or to pins on the decoder socket (but not sure which functions)
http://www.bachmanntrains.com/home-usa/dwg/dwgs/82894.pdf
[/edit]
